What do you mean by "need"? On a warm day you should not need any glow. There is a plug in each cylinder. They either work or are broken.
They could be broken and still start
Mine weren't working when it was -5 and I left the bonnet open long enough to warm the engine and it started
Hate to say it, you have another problem.
I think I still have 4 new ones if you need them.
To check them for operation.
They must be cold.
Disconnect all the plug interconnect wires.
With an Ohm meter check plug resistance to ground.
Good pug will be about 0.5 Ohm's
Bad plug, digital meter will just keep searching
But still, your engine should start after the starter barely engages with no glow plugs this time of year.
My glow plugs are turned off, unless it's <20°F outside.
