This bad boy has ventured all around Europe and was designed by the owner of the overland company "Travel-Fox" which includes the design of high-quality diamond-cut parts ie bumper, window protectors, and storage racks. This Defender build was inspired by the Dakar Rally with intention of going anywhere and having everything within arms reach. No issues and ready to roll. Tagged and titled in SC
Mechanical:
The 300 TDI runs fantastic with only 5,000 miles on it after its rebuild and made its last 600-mile journey without issue. Frame Off restoration was completed in 2014 so there are no rust issues on the frame aside from the normal surface corrosion. The air ride suspension keeps the heavy-duty sleep quarters under control at high way speeds.
Utility:
Popup tent is tall enough for a 6'5 person could stand comfortably in the rear and the full-size bed can fit 3 comfortably. Everything was designed and built by a German engineer with heavy-duty materials and well thought out planning. Off-road ramp holders, cooking area with 110v and 220v outlet options that tie into the solar system. WARN winch with the controller, snorkel, and side awning setup.
Trades Possible
Mechanical:
Utility:
Trades Possible
