I am switching out my taillights and turn signals to LED and having a bitch of a time getting the turn signals to work. Any help or guidance would be much appreciated.
To start with, the turn signals and hazards were flashing when appropriate. Which might beg the question, 'why did I start messing with them?'. To which I might have no good response.
Anywho, I bought the Wipac LEDs and relay from MUD UK. Everything goes fine with the installation of two indicators, so long as they are catty corner, when I plug in the third LED all three lights flash regardless of which way the indicator is turned.
I will have the front left and right rear LED's plugged in with incandescents installed in the other two corners. Turn the indicator LEFT and the lefts flash and the rights do nothing like they should, same goes for RIGHT and they all flash with the hazards on. Now if I unplug the front right incandescent (which is doing nothing like it should be since the indicator is LEFT) and plug in an LED in its place, its starts flashing. It does not matter which relay I have plugged in, I still get the same result.
I've tried flipping the wires in the LED harness, using different LED's on the off chance that I have a rogue flasher and I am getting the same result.
Any ideas for troubleshooting this would be greatly appreciated.
