1 - 3 of 3 Posts
Can anyone point me in the right direction. I need a new connection for my turn signal. I should have removed the other signal to see if it looks the same now that I am thinking about it. It isn't working and upon my amateur diagnosis, I was guessing that one of the male connections broke off.
Thanks
448562
Looks like you'll need a new connector, inexpensive fix! My suggestion would be to clip the factory ones off and replace with some waterproof ones on the light and the truck side. I've been using these waterproof solder butt connectors to splice the wires, they are awesome. You'll just need a pair of wire strippers and a heat gun.
Connectors
Butt Connectors
A quick how to:
Good luck!
1 - 3 of 3 Posts
