1 - 8 of 8 Posts
I will be replacing the bulbs for the exterior lights on my 94 D90. This technology progresses quite quickly. What are a good set of LED bulbs (not cheap junk)?
4 x 1156 (front & rear turn signals)
2 x 1157 (parking/brake lights)
2 x 67 12v4cp (front parking lights)
4 x miniture side parking lights
A load balancer/resistor to remedy hyper flash.
Discussion Starter #2
Interior light replacement and LED upgrade 94 NAS D90.
I purchased and installed all the interior lights (dash and dome) except for one: the flasher or hazard switch back light. It flashes red when switched on. When not on, there is no back light when the marker / parking lights are on.
Has anyone IDed this bulb?
-Dome light:
Part Number: T3.25S-BA15S
T3-1/4 Miniature Wedge Base to BA15S Base Adapter | Super Bright LEDs
Part Number: 194-WWHP5-PC
194 LED Bulb w/ Socket - 5 SMD LED - Miniature Wedge Base | Super Bright LEDs
-Tach:
Part Number: BA9S-G4-90-12VAC
BA9s LED Landscape Light Bulb - 4 LED - BA9s Retrofit | Super Bright LEDs
-Temp & Fuel:
Part Number: 194-G3HP
194 LED Bulb - 3 SMD LED - Miniature Wedge Base | Super Bright LEDs
-Speedometer:
Part Number: 194-G-120 (x2)
194 LED Bulb - 1 LED - Miniature Wedge Base | Super Bright LEDs
-Clock:
Part Number: BA7S-W
BA7s LED Bulb - 1 LED - BA7s Base | Super Bright LEDs
-Temp & Fan switches:
Part Number: #74G (x2)
Box of 10 Bulbs #74G (74 Green) Lamp Miniature Incandescent Lightbulbs Auto | eBay
super bright led's dot com is a wonderful site for these planned upgrades
You want one of the RDX earth Fix Kits versus the load balancers. It runs about $35 bucks and replaces the signal bulb.
The real issue is the factory light sockets are terrible, so fitting just LED bulbs won't provide a reliable solution.
You'll want to purchase the entire LED light unit and replace the entire light units.
Discussion Starter #6
I agree EXCEPT, the 94 has square rear lights; sealed rear LED lights are not available.
In that case I would rebuild the factory units to take more robust sockets that are sealed from water intrusion.
Then you can build in some reliability and still maintain the original lens in the original location.
Discussion Starter #8
Good advice. I plan on doing just that.
Reactions: rdavisinva
1 - 8 of 8 Posts
