1 - 6 of 6 Posts
I'm looking to delete the ignition steering wheel lock from my 1988 row defender 110 lhd. Basically I want to be able to turn the wheel at any time without having to insert the key. I read a few threads but none focus specifically on deleting the steer lock bolt.
I assume I have to remove the ignition switch but wondering if anyone has advice so I don't go astray. Thanks!
Sent from my SM-N950U using Tapatalk
Remove ignition housing, use key to make the security Tang pop out , cut it off with a grinder , reinstall!
Thanks! While I'm in there I figure to replace the ignition lock with something more durable. My rear white cap I can see starting to separate. Any particular brand to buy or avoid?
1 - 6 of 6 Posts
