Im rebuilding the axles on my "97 NAS D90. When I follow the workshop manual, and I mount a dial indicator guage to measure the end float- to get any movement on the gauge- it seems that the adjusting nut is illiogically loose. If I tighten it down as per the manual to 50NM torque, back it off 90 degrees and then tighten it back to 7 NM as per the instructions I dont get any reading on the gauge at all as I try to pull on the hub. I only get the recommended .004 of an inch on the guage when I lossen the adjusting nut so that it is barely hand tight- is this right? It seems like it should be tighter than that. Thanks!
David
David
