1 - 4 of 4 Posts
Introducing our new High Amperage Battery Disconnect Kit!
Price $179. Source members save 10%
Use Coupon Code SOURCEBATTERY1 at the top of the checkout page to receive your discount
https://garrisonoutfitters.com/product/battery-disconnect-switch-kit-prc4879/
Off-road-ready, these spring-loaded switches are used throughout Europe in military, commercial and agricultural applications for their vibration resistance and high surge tolerances.
Our master disconnect switch is an in-line rotary switch with lockout capability and features a sealed, robust housing that is weather-resistant to IP65. This kit is a complete solution that contains everything you need (save for the tools) to get the job done! In your kit you will receive the switch, with custom powder coated handle, a Defender-inspired, custom designed anodized aluminum bracket with bump guard and lockout tab, premium quality connectors, heat shrink and fasteners, a GO Edition weather-resistant Abus padlock with two keys, an aluminum housed, weather-resistant LED status light, a mounting template and full-color detailed installation guide. Our kit comes complete with an anodized aluminum lock-out bracket with bump-guard, custom designed for the footwell area of your Land Rover® Defender, which enables our weather-resistant Abus padlock (included) to be inserted in the "OFF" position as a mild theft deterrent and to prevent accidental activation during vehicle maintenance or repair. (Complies with OSHA lock-out/tag-out regulation 1910.147). Our kit also features a weather-resistant, aluminum housed LED status light to let you know when your system is activated. To round-out our kit, we have sourced the best quality components such as premium tinned-copper compression terminal ends and premium dual-wall heat shrink tubing with a weather-resistant internal adhesive. Each and every component of this kit has been thoughtfully selected to provide years of reliable performance. These selected components meet the rigorous overland needs of resistance to weather and vibration. We back our switch with a Lifetime Warranty to the original purchaser!
In case you missed our sale post in another thread, you can save 20% off these Premium Battery Disconnect Kits until tomorrow, August 6th!
Sale ends tomorrow, Tuesday August 6th!
Save 20% while you can!
Use Coupon Code GOSUMMER2019 at checkout to receive your discount!
Best regards,
Paul
Discussion Starter #4
Sale ends TODAY!
1 - 4 of 4 Posts
