I'm about to install a Lokar shifter/gear selector. I have the shifter unit/assembly from Lokar as well as the adaptor plate from Nick/RW-engineering.
Before I start to take things apart, anything I should double check. Is the install process straight forward? I'm starting from a somewhat make-shift set-up from a previous owner (see attached). Truck is a 4.0L V8, LT230, ZF HP auto.
