1 - 6 of 6 Posts
Hello, I want to change my clutch kit.
My truck is a Land Rover Defender 110 HARD TOP 300TDI . It was produced on 1997. The engine is 300tdi. The gearbox is R 380.
Please answer the following questions:
A) Which clutch is preferable / you would use /, for what reasons :
1) Land Rover Performance Clutch Kit - OE STC8358
Item number: 3000.950.701-S
manufactured by the company SACHS : Land Rover Performance Clutch Kit - OE STC8358
OR
2) POWERspec TDI 200/300tdi
manufactured by the company LOF clutches : Land Rover TDI Clutch kit Heavy duty - Discovery/ Defender/ Series 300tdi
OR
3) KLR24006-1A Xtreme Outback Clutch Kit-100 Series
manufactured by the company Xtreme Outback Clutch : Catalogue - Xtreme Outback - №KLR24006-1A
B) For LOF clutches:
  1. What is the % higher transmitted torque of the POWERspec TDI 200/300 tdi kit compared to OEM? Land Rover TDI Clutch kit Heavy duty - Discovery/ Defender/ Series 300tdi
  2. What is the torque capacity of the POWERspec TDI 200/300 tdi kit in Nm ? Land Rover TDI Clutch kit Heavy duty - Discovery/ Defender/ Series 300tdi
  3. What is the clamping force /eject fors/ of the POWERspec TDI 200/300 tdi kit in N or kg ?
    4) What will be the weight of the pedal if I install /put/ a 2.8 TGV HS International POWERspec kit - (Also fits TDI) and a DEFENDER POWER MASTER BUNDLE Spring and Master Cylinder on my truck?
    2.8 TGV HS International POWERspec kit- (Also fits TDI) - Land Rover Clutches
    DEFENDER POWER MASTER BUNDLE Spring & Master Cylinder - Land Rover Clutches
    5) The weight of the pedal from point 4) is equal to or less or greater than if I mount /put/ on my truck POWERspec TDI 200/300 tdi kit and Defender POWER MASTER BUNDLE Spring and Master Cylinder?
    Thank you in advance.
I do not speak English! I use google translator.
This will work just fine....a 130 clutch like I have in my 200tdi 110, that I use for towing and bringing in wood or a standard clutch is just fine.
Don't buy Britpart IMO.
All the best.
I’ve used the LOF kits in several vehicles. Seem very well made and I really like the wire TOB retainer to replace the plastic staple.
I usually get the power spec kit. Motors are stock, and my heaviest truck is a 5 door 110 with an Icarus top. I’ve never had an problems with the power spec clutch, and don’t notice any difference in pedal pressure.
All the best.
Thank you for the advice.
Thank you for the clarification.
1 - 6 of 6 Posts
