1 - 10 of 10 Posts
· Registered
2005 Range Rover HSE
Ive got an 87 D90 RHD prior 2 tank diesel that was swapped to a 3.5 petrol somepoint prior to my ownership. Trying to sort the 3rd world wiring job prev owner created. What is this component under the instrument binnacle?it been unplugged since Ive owned it Cant find any decsription in wiring diagrams. Thanks for your help in advance
· Premium Member
Looks like a relay that won't allow the headlamps to work unless the ignition is switched on is my guess.
This theory is based on decoding the wire colors.
white = ignition
blue = power to headlamp switch
blue with red = low beam headlamp
red = parking lamps
The problem with providing any further information is the pictures you supplied don't show the area where the plug fits, nor does it show exactly where the plug goes and if it is a relay what the pin numbers are where the plug fits.
Without more information, it's impossible to be certain.
· Registered
It's "Lucas"...keep it unplugged.
Ahh yeah I cant photo the plug pin where its located onthe module. I suspected was something of a relic from its prior life as a diesel but this makes sense
· Premium Member
So are you saying that these 2 parts provide the same functionality, because they sure look different in the pictures unless the first photo is a side view.
Inaccurate pictures generate inaccurate responses, I guess.
click to enlarge
· Premium Member
It does not seem to be a land rover part, perhaps some kind of power amplifier, signal stabilizer, part of a uhf radio maybe.... it has heat sinks for cooling so it must have had some kind of power output.
Remove and inspect all sides, it may have something to identify it's purpose.
· Premium Member
So it’s a dim dip controller. That’s one of those Euro mandates. It controls the headlights. A sensor senses headlights of an oncoming vehicle and flips the headlights from full beam or brights to dipped beam without the driver’s input.
my F150 does the same thing and honestly I like it.
1 - 10 of 10 Posts
