1 - 3 of 3 Posts
1995 NAS D90 w/ AC. All of the air is going to Defrost. Heat / Defrost Lever is moving so I assume the cable has disconnected or is broken. What is the best way to access the heater box to replace / reattach the cable? Thank you.
I had a similar issue, and it was the attachment point on the control lever that was loose. I took off the side cover and was able to tighten it up from there.
1 - 3 of 3 Posts
