You speak of course of the days before home security cams...😳
You speak of course of the days before home security cams...😳The loud neighbors exhaust could have been fixed with a potato in the exhaust pipe.
It came from the factory with EFI and a coil pack from 95 to 98. So there’s no extra work needed. Solid state coil packs often last the life of the vehicle. The coil packs on my E30 are over 30 years old.Like this?
too much work, what’s wrong with a rebuilt Rochester? They are on every 250,000 mile inline out there! Worked on the early 60s - 70s base muscle cars.
Vendo um motor GM 4.1MPFI da Silverado...
Motor completo...
Comprei o motor aberto e com cabeçote trincado (sem saber).
Foi feito:
Troca do cabeçote por um novo (zero mesmo);
Troca de velas;
Troca de filtro;
Suporte e calços novos;
Correia;
Revisão do alternador;
Troca da bomba d´agua;
Troca de oleo;
Juntas;
E mais algumas coisas que não me lembro...
Entre a compra do motor e fazer tudo isso.. Gastei mais de 5,5k...
Quero hoje 4,5k
Good points.Good point.
The Chevy 250 is bullet proof.
The engine has maintenance free metal timing gears and is 100% reliable.
As such, there aren't any timing chains or belts that need to be changed.
You guys may not know this tidbit: GM sold the older version of the Chevy inline 6 cylinder engine to Toyota.
That's right, the inline 6 that ended up in the Land Cruiser was the earlier Chevy engine with manual valve adjustment.
When Chevy came out with the larger displacement hydraulic lifter engine, they sold the older version to Toyota.
Did you also know that Rover V8 owners are swapping their distributor to GM Delco HEI?
Why?
Because it is reliable.
The same reliable distributor that is used on the Chevy 250, albeit for the 6 instead of an 8 cylinder.
Way faster and more capable than my 19j. I have a video of hitting 40 mph here.Good points.
My question is: does the Chevy 250 make enough HP? Can I cruise in 5th gear on the hyway, up hill at 5000+ feet on a hot summer day into a head wind (without collecting a large line of cars behind me)?
Thank you.Hanzo nice set up…any issues with overheating being your 60 over. I’m building another 250 I went 30 on the other
engine, I’ll have some more info later on. Besides 60 over on the cylinders, what did you do to the head, just curious what were you looking to do with engine Increase HP and torque. Let me know
chris
Not really sure how much power. I was told I should get 12-15% power increase over what a stock 68 Camaro would put out.The power manual is the 2nd edition?…..what is your anticipated Hp and torque…being 60 over you did change ythe cam ? It looks like you’ll be breathing better with the modified head….and how did the break in go on Saturday
