1 - 11 of 11 Posts
So im ripping into my Series 2A.... taking everything apart getting read for media blast, galvanziing, paint powder coat etc.
I want to galvanize the door frames. I noticed the skins on the front door tops are steel, and a bit tougher to pry off than the Aluminum skins on the rest of the door frames.
If i want to galvanize these door tops do i have to remove the skins first? No doubt there is some rust under them between the frame and the skins. Just wast sure what the standard procedure is here.
Any reason why these are steel and the others aluminum? Is that original or perhaps these were replaced once with cheaper steel versions?
The skins are aluminum. Its easier to carefully deskin them that it would be to make new ones.
if you want to keep it original looking galv is the way to go, but if you dont mind, then the Rocky mountain, or a set of ExMOD would be decent an alternative.
-Jeff
Ok - then these were deff replaced at one time. The rest of the skins are all alum but on both front doors the tops are skinned in steel
Doug - will the defender tops fit these doors? Those show 84-present. Truck is a 67 IIa
no need to buy new, the frames are in good shape. I'm going to be stripping and galvanizing alot of stuff so it would make sense to just "freshen" these up instead of replacing.
Ok - then these were deff replaced at one time. The rest of the skins are all alum but on both front doors the tops are skinned in steel Doug - will the defender tops fit these doors? Those show 84-present. Truck is a 67 IIa no need to buy new, the frames are in good shape. I'm going to be stripping and galvanizing alot of stuff so it would make sense to just "freshen" these up instead of replacing.
Yup they will.
1 - 11 of 11 Posts
