Fuse panel bracket
177 Views 5 Replies 5 Participants Last post by  seekerbeta
Are the big screws that hold the fuse panel bracket to the bulkhead fully removable? I can back them out about 50% but then they stop. I'm afraid to sheer off the head or fully round out the screw. I'm trying to get to the wiring behind my fuse panel. Pic attached of large screw on far right. This is for a 97.
Thanks!
See less See more
1 - 6 of 6 Posts
Yes they do come out completely.
Reactions: 1
PB blaster on both sides might help
Reactions: 1
They are supposed to come out completely… you may have to crawl under and clip the end off after screwing it back in, and then back it out. Or, cut the head off and send it all the way in.
Needless to say, new screws are required.
Reactions: 1
Thank you all! Does anyone know the size/thread pitch so I can order new ones?
looks to be Screw-pan, M6 X 12MM, i replaced mine with bolts so i used M6 x 12mm bolts
Reactions: 1
1 - 6 of 6 Posts
