1 - 8 of 8 Posts
Need a stock front radius arm to replace my jointed front radius arm. When was the last time you saw one of these?
Located in Wake Forest NC.
463424
RTE made those kind back in the day. My brother had one on his disco 1 Rock crawler.
Mine has been on the truck 15+ years. Pin has started getting loose. It clicks when I tap on the brakes. About to change bushings and figure it's time to take it off. Have 9012 shocks in the rear still with Rockware cones and shock towers. Running Puma 90 springs which I was surprised to see were the same height unloaded as the OME 764 springs I took off. I'll probably keep the rear set up as is.
I have a pair, but if you have a local pull your parts place, you could save freight and yank from a disco if available. Let me know and I can always check costs.
1 - 8 of 8 Posts
