Selling an used Land Rover Defender 90 (ROW) rear crossmember with extensions (Proline brand). Purchased from Rovers North in late 2017 and installed that winter, however only used for the summer of 2018 for roughly 200 miles, as I ended up doing a full galvanized chassis swap the following winter. There is not a speck of rust on the crossmember and it is in great shape. Backside and inside sprayed with waxyoil.
Please note that the ends of the last few inches of the extensions were reinforced/overlapped with extra steel when installed, as the original rear crossmember was already swapped before, which left very little chassis left to slide the extensions over and weld to. I point this out because the last few inches of the extensions, although reinforced now and very solid, are thicker than normal since they are 2 layers thick and therefore would likely need to be cleaned up a bit in order to slide over the chassis if trying to create an overlapping joint/weld.
Hello, Not sure if there will be any interest in this but I have have a 2.5 Petrol from a 1991 ROW 90 that was running fairly well before removal. Name the price, come and get it and save it from the scrapper. Thanks.
ALL prices include shipping
73mm and 95mm take off lights: $100 for the lot
AMR3850 95mm light plinths: $30/set of 5, $25/set of 4
NTO Spal 30101500 fan w/Delphi plugs, 962CFM puller: $50, 6 available
Used ANR3231 48 spline (91-07) steering wheel, see second pic for condition: $50
Used 300tdi...
