Flasher relay for LED blinker lights
31264 Views 122 Replies 38 Participants Last post by  brettm
I have ordered LED replacement lights for the dash lights and the exterior lights from superbrightleds.com. Should get the delivery today. I know I will need a flasher relay for the blinkers. Does any one know a source and part number for the needed relay. The ECR replacement light package comes with this relay, but I am trying the DIY route.
I will post the part numbers on the lights once I find out what works.
thanks
See ECR instructions on the install:
http://www.eastcoastrover.com/LEDflasher.html
------ Follow up post added May 19th, 2010 07:42 AM ------
thanks
Nevermind, I found it:
CF13GL-02
121 - 123 of 123 Posts
I got the bolt on bits adapter and it works as described, but...... It's rather dim compared to the bulb that was in there. Anyone else experience this? For a $60 bulb, I guess I expected 100 percent install satisfaction.
PSA.... Check your wires and make sure + is correct. The whole front of my truck was wired backwards. Now the whole truck led project is complete.
3
Just did the diode-fix for this, was pretty simple. Wrapped the diodes in heatshrink and then butt crimped each end to make a connector I could insert between the cut wires.
For 97 NAS the green-white / green-red wires were located on the 10-pin connector closest to passenger side.
See less See more
