1 - 11 of 11 Posts
· Premium Member
Hi all - what's the correct hardware/parts and method to secure the rear reflector to the crossmember? Part #s AMR2076
One hole is easily accessible behind the crossmemeber - the other is not : /
· Premium Member
Discussion Starter · #8 ·
For posterity and those who have asked for the part number: AMR3310 per the parts catalogue, but NLA. I'm ordering a set of MWC9832PMA from RN today and will follow up here if its a good fit.
· Premium Member
The Disco 1 has the same Perei ones as the 95 & 97 NAS Defender. They're NLA too, but can be found at the junkyard pretty easy. They attach with a little plastic grommet. Just drill a hole a hair smaller than the grommet and tap it in. Then push the reflector on.
To remove the ones off the Disco you need to remove the trim pieces on the rear bumper that contain them, then carefully cut the metal clips off the back so you don't break the plastic nubs.
· Premium Member
Discussion Starter · #11 ·
unfortunately the above part from RN does NOT work.
I've ordered a set of generic fir trees that measure 6.25 mm 12mm head diameter and 11mm length.... when those come I'll update this thread again
1 - 11 of 11 Posts
