1 - 8 of 8 Posts
Gentlemen,
Anyone have to track down one of these fuel tank emissions manifolds? It is the three valve device coming out the top side of the fuel tank.
Rovers North has the P/N on their website, but also says call for availability. Afraid it might be NLA.
Mine leaks raw fuel when the tank is filled. Don't want to try to take it off until I have a replacement, in case its too brittle and breaks up when moved.
there's nothing to this device from as far as i could tell on mine. it's just a box with a couple inlets to allow condensation of fuel vapor and then it's return to the tank. very much like the tdi cyclone filter. its a particular shape, but i'm sure you could find aftermarket equivalent and come up with a mounting adapter for same bolt holes.
if you have a rotted one, this should be an easy duplication project for a decent fab shop.
I used one from a Disco. They are hard to get to since they are inside the RR bodywork. I made a bracket and kept the one way valve that was on the disco. Seems to work.
for petrols, the only thing about it that needs to work is for the emissions inspector in your state to see a box or can shaped thing somewhere with lines coming in and out. you have that and mission accomplished. no ECU to keep happy here folks.
1 - 8 of 8 Posts
