1 - 20 of 34 Posts
After resolving all previously posted issues, it was time to hit the road. It road smooth and the engine was humming. After 30 mins of driving the oil light came on and a loud ticking noise started in the engine. LOUD. There has always been a barely noticeable ticking noise from the engine but nothing like this. Despite oil light, No oil loss detected. Sounded like an exhaust leak near manifold. No exhaust leak. I checked the plugs because it almost sounds like a loose plug ticking. No plug issue. The noise seems to come from the under the valve cover. When I am underneath the D-90 the noise is loudest toward the firewall. The noise matches the engine at idle and after revving the engine.
Fault codes are P0300, P1316, 1317. Of course the check engine light was on prior. (I usually reset that as needed so disregard). The P0300 code was unusual. Never had an issue with the engine EVER... and I have had the 1997 NAS since 1999! A while back I researched the earlier ticking noise and the piston rod/rockers were suggested as a possible cause.
What say the forum?
------ Follow up post added June 26th, 2015 06:43 PM ------
clip with noise https://youtu.be/vL-1Ae8U77A
I dealt with this issue a couple of weeks ago on my '97 SW. Check engine light came on and I had the same exhaust leak sound. I also noticed a decrease in power. The code thrown was P1317 which states "ABS Rough Road Line Low Fault". I also found where is stated that it was a "Manufacturer Controlled Ignition System or Misfire". I changed the plugs and wires, cleared the code, and it seems to be fine. The exhaust leak sound is gone and the check engine light has yet to come back on.
I would suspect that it is the bypass valve sticking open and causing low oil pressure as a result sticking open. When I rebuilt my oil pump, in addition to replacing the gears, I had to sand down with an emory cloth the valve piston in order for it to move freely inside the front cover/oil pump. Something worth looking at
Check Oil Pick Up Tube Screen...might be plugged with crap.
Where is that located? That sounds like it's worth a look.
Based on other folks' input on this thread I have new plugs and wires coming. The oil pump sounds the most challenging for my driveway workshop.
NOMAR: I drove it about 1.5 miles like that.
Where is that located? That sounds like it's worth a look. Inside the oil pan. You will need to drop it.
NOMAR: I drove it about 1.5 miles like that. Ouch
Any time you get a warning of eminent failure, shut it down.
I was going 70MPH on the highway when my temp gauge headed for red. I shifted into neutral and killed the engine while still traveling highway speed.
Luckily I was coming up on my exit. I had enough speed to even coast off the service road and into my neighborhood street.
gems engines have a different oil pump design which unlike the 95 and older trucks is self priming. I had a disco where the light came on as I drove it home from buying it. I pulled the pan and sprayed the oil pick up screen out
with gum cutter and I never saw the light again.
Banned
The lifters are knocking because they are starved of oil. Not good thing espetially for 1.5 miles. Thats about 5 minutes of probably 2000-3000 rpm driving without oil! You've done some damage for sure. How bad is anyones guess untill you remive the pan etc... and start tye engine again.
Dump the oil in a clean container without spilling any especially when jt starts comming out as your going to run a magnet through the oil to check for metal particles. Often times going by tye color and size of the particles the damage can be traced to particular engine parts.
You will need a new gasket if your old one looks unusable or some silicone when putting the pan back. Remive pan and move to one side. Reach up and into the pan with your hand espetially at the bottom because thats where a large amount of metal shards if any would reside in the sludge there. You can easily feel them uf your. It wearing gloves. Put all sludge in the same oil container for later inspection.
Take pictures of the metal shards and post up for identification.
The oil pickup is easily accessible. Remive the 2 bolts holding it and take it off. Inpeact for clogs abnormality of any kind.
Post up with what you find. If you find a larte amount debris in oil / pickup you will also need to change the filter as that will also prop be contaminated with same. If you find want to be thoroug I would also cut the filter in half and look for metal shards.
Discussion Starter · #17 ·
I surveyed the 90 today and turned it over for a minute. In 15-20 seconds the loudness of the ticking noise subsided and went back to the original subtle ticking noise the engine has had for years. The oil light never went ON. It idled for a minute before turning it off. The noise appears like it's coming from under the valve cover where I have believed the subtle ticking noise has always emanated from.
Q: I cannot feel any vibration that corresponded to the ticking on the valve cover. Should there be a vibration?
Q: Shouldn't the light remain ON if the oil is not circulating?
I am assuming that if the pump is shot-out then it's condition should be the same when the 90 up today. It sounded normal. Could something be sticking or malfunctioning after the engine heats up? Flananuts mentioned that the bypass valve could be sticking open and causing low oil pressure.
Of course the problem is still there; I am looking to get it trailered out for service. Just curious if this changes anyone's diagnosis before I drop the pan and do some inspection work myself.
FYI: The 90 hasn't been driven that long (30 mins) in over 3 or 4 years. I fire it up and have taken it for short runs around the area but I haven't driven it continuously for a long while due to different projects and problems.
Thanks to everyone for taking time to provide input. It's much appreciated.
Others might have a different idea, but I'd remove a qt of oil and replace with ATF. Run it in your driveway or drive around but keep it close. Stop if loud ticking or light comes back on. The ATF is loaded with detergents and will help dissolve and clean out what sounds like buildup of sludge (edit - or varnish flakes per Doug). Put 15-30 minutes on it and change the oil filter (if it feels extra heavy, that is good). Top off with oil and repeat. Then change filter and oil.
Angel gear....
Yes, what Russell said. What you are experiencing is varnish flakes in the pickup screen. I doubt its sludge. The noise you are hearing is likely an exhaust leak between the head surface and exhaust manifold. The varnish flakes will drop off the screen into the pan when you turn the engine off and will pick back up under suction as you drive the truck around.
When i experienced the same scenario I was amazed how clean the engine actually was but the issue was the truck had sat for long periods like yours and varnish deposits (hard caramel looking stuff) formed in the pan.
1 - 20 of 34 Posts
