21 - 21 of 21 Posts
Where did you put the fuel pump? Which one did you use Where did you put the regulator? Can you share photos?
I used an in tank High pressure fuel pump, the sniper wants 65psi so the same one used for LS conversions works in this case as well. It has a regulator on the input of the sniper. plump in the 2 recommended filters somewhere on the frame rail.
21 - 21 of 21 Posts
