fuse is most likely. You will have to install smart load unless you change to a flasher relay that's designed for LED.
You gonna go through a lot of fuses if you are doing a skin voltage test....Replaced the fuses. My turn signals work.
I took a volt meter and measure voltage from the wires... im getting almost nothing, like 0.2V at best. When i held the volt meter to the ground and the black/green wire, it burned my thumb a little but so i am getting some voltage on the black/green but nothing on the red.
Any help is GREATLY appreciated
See the opening part of the sentence “unless you are hot-wiring stuff with the circuit energized”.So you blew the " impossible to blow fuse". Glad you figured it out.
Stop light is a separate fuse from sidelight. Seeing your luck with the fuses, might want to check that one as well. It’s typically on the same circuit as the dashlight and turn indicators.Still getting no light with the ignition key in the "acc" or "on" position with the brake pedal depressed. Somehow the green wire is getting voltage but the red is getting none.
Is it possible i broke some sort of connection for the red wire? any ideas why these LEDs are still not giving off any light?
thank you thank you
