1 - 4 of 4 Posts
Ok silly question but do the have a set of 4, and do the longer shock go in the front or the rear?
I should know this but
Depends on the types of mounts you have, but the front will never flex like the rear can.
Zack,
Thank you! Makes sense. If I use the Rockware mount I picked up from you then the longies go in the rear. I will have to modify or pick up a set of front shock mounts that are lower than my current set..
1 - 4 of 4 Posts
