The factory 4 cylinder Defender line from the clutch master to the slave typically has 5 connections: Adapter from the master cylinder (1), the adapter to the metal line (2), metal line to rubber line (3), rubber line to short metal line (4), metal line to the slave cylinder (5).
Often think if I were trying to design the most ridiculous setup, it would be exactly what Land Rover came up with.
Since the Dorman clutch master cylinder uses a flex line, all the original lines and connections are redundant.
All that is needed is a fitting to go between the new flex line and the slave cylinder.
Found a double flare fitting in an assortment of parts in my shop that screwed directly into the slave cylinder and had the correct flare fitting for the new line.
The result is shown.
Please note the pictures are from a 110 undergoing extensive work including an engine conversion, so they are not pictures of a finished product by any means, so things will get tidied up in the future.
The pictures are only meant to show the new cylinders, line, and the 2 connections.
Click to enlarge.
Click to enlarge.
