1 - 4 of 4 Posts
I have a RHD 1991 200tdi 90. I'm interested in replacing the gauge cluster with a DIY Tablet/Raspberry Pi/Arduino solution. The feasibility is not the problem: there are plenty of posts on the internet doing this. My main concern is legality. Does anyone have any insight on what it would take to make a digital instrument panel street-legal? Does the legality vary state-to-state?
On the more practical side, what are the mechanisms/principles of operation for each of the following:
1. speedo
2. fuel level
3. coolent temp
4. battery voltage
I'm specifically trying to find out how they work so that I can figure out how I would go about interfacing them with either an Arduino or a Raspberry Pi.
If I wanted to add the following to a digital dash, are there existing mechanisms/sensors in place that I could access to read:
1. rpm
2. oil temp
3. turbo pressure
While I'm at it, does anyone have suggestions for gauges or sensors they wish they had, or things they feel they don't need?
ive never heard to seen any laws that say you have to a have a specific gauge type. id take alook at the VDO gauge guide thread it lists all the senders, you can then look them up and see how they transmit.
For a lot of the gauges, the madman system seems to work well. I’ve wanted one but they always seem to be on back order. If you find a way to provide the same results, I’d be interested
Most of those sensors you list are essentially just variable resistors, calibrated to a control voltage. The gauges to track rotating things operate on a PWM signal (in any application I believe, not just your TDi).
A quick google:
If your TDi has the stock gauges, the three you ask about having senders do not exist, unless you count the alternator for the tachometer.
A RPi might be overkill unless you are going for full-color, animated display. In that case I would look at a RPi compute module, intended for industrial applications.
1 - 4 of 4 Posts
