1 - 4 of 4 Posts
I'm wondering if someone might be able to take a quick measurement for me. Working on the install of disco 2 second row seats in the defender and I'm looking for the following dimension:
The second row seats are secured to he floor with four pivoting brackets, I'm looking for the distance (from center of bolt to center of bolt) between the middle two brackets.
Thanks in advance!
Like this?
You don't have a shot of them mounted through the floor do you? I'm still debating exact for and aft position. The further forward the better for the seatbelts, but worse for leg room. Also debating raising them about an inch so I don't have to recess the rear latch in the floor, but again concerned raising it might cause interference with the rear seatbelt spools and window trim.
1 - 4 of 4 Posts
