1 - 4 of 4 Posts
I have an 83 110 and purchased all new door locks but the locks do not work, they just spin for the 4 doors.
For the rear door I also purchased a new mechanism and lock. The rear door lock works when the door is open but not when the door is shut.
If the lock just spins then the linkage may have fallen off. A tab is screwed onto the backside that holds the linkage. The rear door may just need to be adjusted. On the older trucks the catches are usually pretty worn and may need to be replaced.
Where is the ball bearing, should it have come with the new locks?
As for the rear door, that is what I was thinking, but before I start adjusting it I thought I would reach out.
Thanks
1 - 4 of 4 Posts
