1 - 3 of 3 Posts
I recently brought in a customers d90 v8 gas powered rover in to the shop. It had been sitting for a long while, a year or so , and I was given the go ahead to replace a bunch of parts , from brakes to suspension.
I installed a new battery , and tried to start the vehicle. It will not crank unless you keep the key in crank position. then after a few seconds it will crank, but still no start.
Went and checked for spark, None, fuel injection pulse, None. So I figured it must be ECM related. So I checked the main harness at the ecm, no problems there , clean, so then I figured to check the main relay. It was not enacting while cranking , I checked the wiring into the relay and looked like I was not getting a ground to close the relays.
This car has the alarm module under the dash board but I am not sure t its even working. Does anybody have an idea how to check this to see if its interrupting the signal for the relay box? or is there a way to bypass it ?
Im stuck on this now, I have replaced all the parts needed I just have to get it running.
Please guide me to a site or name of a good rover mechanic who can help.
thanks a bunch
Al Kilgore
Al. I am no mechanic and others will have much more insight but this is my thought. Take off the steering column cover (Plastic) and reach inside the dash. Behind the ignition key tumbler assembly there is a plastic cylinder. Stick a finger back there and pull it towards the key, and try to start it. I have had two of those ignition switches fail and it did exactly what you are describing.
EDIT
After thinking about this some more, I started thinking about this from the perspective of easiest to hardest. If the ignition switch is good, then I wonder if it is the ignition control module, which is the little plastic thingamahopper next to the coil. From there I am past my guesses.
1 - 3 of 3 Posts
