1 - 4 of 4 Posts
getting ready to flush....have a 200tdi, any BRAND recommendations. Has blue/green in it now.
thanks!
Color should not be the determining factor for adding or mixing coolant because it is not standardized or indicative of chemical makeup. If you are sure you can flush all the coolant out, I'd go with an HOAT coolant such as Zerex G-05, if not I'd use a universal mix to avoid consequences of mixing incompatible coolant types.
I have been using Peak Final Charge for years in 5 Landies and the John Deere tractor.
1 - 4 of 4 Posts
