1 - 16 of 16 Posts
i have a 93 200tdi.. just today after getting truck up to temp the guage reads a tick above cold. ALWAYS reads a little below halfway. nothing seems out of sorts. im guessing guage has taken a dump? is there a difference in temp guages? Rovers north has one for a manual, and one for automatic.
Get a VDO unit with real numbers, do a serch on here for VDO guide
Most likely it is a bad wiring connection and not the gauge.
Verify with an infrared heat gun.
what temp should i be looking for?
The thermostat should start to open at 88 C (190 F). Measure the temperature where the thermostat housing connect to the head once you heave reached operating temperature. It should measure close to that. If it is low (like the gauge shows), then the thermostat is probably leaking. If it reads normal, check the gauge to sender wiring. A low reading can mean there is an issue in the sender wire.
Probably, but you'll have to match it up because the counter person won't have a listing for the part number.
Discussion Starter #9
I
Its low..(130f)
does napa carry a 200tdi comp thermostat if needed?
Yes. Same as all modular Ford V8s and V10s. Stant 13779 or 45779 (superstat)
That is where it should read.
my 300 always read slightly over half when warmed up. I replaced it with a real VDO gauge and its reading 185 or so pretty much no matter what.
1 - 16 of 16 Posts
