61 - 80 of 97 Posts
· Premium Member
Discussion Starter · #61 ·
So problem one, gearbox cross member….. taking it out just as hard as putting it in. It lifts the entire chassis when I push up on it with Jack, so, I used my car lift to hold it down and boom!
Next problem is dust cover under starter and covering back of torque converter, I was sent the wrong one….. so I will wait for new one.
· Registered
FYI a chassis spreader is the best way to get the cross-member in & out
We have one similar to this
· Premium Member
Discussion Starter · #69 ·
Kolby did provide engine mounts and adapter too. He was out for a while and I had some issues while he was out, when he returned he took care of it. He did awesome!
· Premium Member
Discussion Starter · #71 ·
Well, another learning lesson!
When mounting the transfer case, the housing on the transmission (not sure what exactly it is called ) that tapers the end from 2 wheel drive to four wheel drive doesn’t fit stock , it will hit the corner of transfer case when mounted. So, after a little guidance from one ten (thank you Sam!) I cut the corner off and it fits!!
· Premium Member
Discussion Starter · #72 ·
Ok, another lesson, as I was attempting to mount the transfer case mounts to chassis, things weren’t lining up. Come to find out the housing unit that mounts after the transmission k between the adapter is more than .25 longer than it is supposed to be. Bought the right part and now we will see if it fits.
· Premium Member
Looks great, I have a big tank on mine and I've been wondering what to do for a rear sway bar since it hangs down below the mounts. Have you thought about that yet?
Still love that frame lol.
Sean
· Premium Member
Discussion Starter · #76 ·
Well I haven’t tried to mount it up yet, I was told the stock sway bar would fit with this tank, I guess I will try to mount it and see what happens. Standby…
· Premium Member
Discussion Starter · #77 ·
After mounting up transfer case, still off about 1/2 inch. In addition to that, my left exhaust manifold is too close to frame. A suggestion was made to me to raise motor mounts up about 1/2 inch above frame rail, which is almost an inch from where I am at…. So….. motor, transmission and transfer case back out…. Cut off stock mounts, welded in new mounts about 1/2 above rail and everything fits. Transfer case now mounted up and exhaust manifold fits. 1 step forward after 6 steps back. Now I can move on to something else :)
· Premium Member
Discussion Starter · #79 ·
I’ve been working on the fuel system.
Ordered a d2 fuel pump module assembly.
Pulled the stock pump, Installed the walbro pump f20000141bx .
Making the modifications to fit the pump was a little tricky. I used a small dremel to make the whole larger on top.
I ordered some replacement high pressure submersible fuel line for inside the tank. Is everyone using 100 or 300 psi rated lines inside the tank?
I also ordered my fuel line from my filter to the tank. I used RaceFlux Lightweight Viton Racing Hose from RaceFlux Custom Made Hose Assembly, -6AN
· Registered
NIce project you have going here. Just found your thread and picked up some great ideas. Following along. Dont forget to put a heat shield on your motor mounts or they could meeelt.Where is the tank from?
61 - 80 of 97 Posts
