1 - 9 of 9 Posts
Don't assume it's bad. Test it first. It could just be corrosion on the connectors.
I'm also having a recurring TPS fault. I can check for clean connectors but couldn't find a test procedure for the TPS in the manual. Can you tell me how to test it? Is it simply a continuity test across the full range of motion or what?
The attached is 93' RRC Multiport Fuel Injection Electrical Troubleshooting Manual. This should be of help. Look at Test G. I haven't looked at my Defender work shop manual yet. Will scan the applicable pages and post here in the next few days. Thinking the TPS test will be the same.
Connect you multi meter ( set to 20v DC ) between the ground ( battery -ve ) and pin 20 on the back of the ecu ( you'll need to remove the cover ).
you should see it start around 0.3 v and max around 5v. The progression should be smooth over the full travel of the throttle pedal. If you see any spikes or out of sequence values it would indicate a 'worn out spot' and cause for replacement.
An old fashioned analog meter is best for this test or something like a fluke that has a digital bar graph 'needle'
1 - 9 of 9 Posts
