1 - 4 of 4 Posts
Clearing out my shed of collected parts from trucks and/or projects that will never happen. Prices listed exclude shipping (will be from 80302). Pics forth coming.....
Stage One Grille MRC6620 - $140
Set of Wolf/WMIK under seat battery clamps (top & bottom) - $30
Lucas Ignition Coil 4-cyl PRC9858G - $20
Flame Thrower Ignition Coil for 4-cyl LR - $10
Fuel Sender from series (New) PLE494 - $50
Wilwood Master Cylinder 3/4" (replacement for most series/LR, New) - $70
Puma heater blower assembly - $120
Fuel Pump Overhaul Kit, two available AEU2760 - $10 each
Water Pump TD5 STC1086 - $15
Silicone Turbo Hose kit for TD5 (includes metal pipe) PM992 & PNP101250 - $100
Front Middle Seat Techno cloth/vinyl - $100
110 Rear Inward Facing Bench Seats (3 person per bench) & Seatbelts & Mounts - $300 (will be heavy shipping).
Polybush Red Radius Arm to Chassis kit GAL117R - $60
Rear Fog Lamp PRC7254 (genuine take off/used) - $10
Firestik Antenna Spring SS-3M - $5
Firestik Antenna Spring SS-3H - $5
Everything below is Best Offer:
- plastic dash binnacle mounts (two available)
- LH wing cover, with vents
- RH wing cover, solid
- Land Rover tape radio AMR2772
- Sony CD/Radio CDX-R3000
- Series Underseat Tank, 552176 (taken from a 67 Series)
- Used Indicator/Horn/Dim/Dip Switch XPB101290 (still works)
Cheers,
Mike
Discussion Starter · #4 · (Edited)
Can't edit, so updated list.
Link for parts pics: https://goo.gl/photos/xH9uwj7amFqNgHCX8
110 Rear Inward Facing Bench Seats (3 person per bench) & Seatbelts & Mounts - $300 (will be heavy shipping). Pic in link above shows before removal.
- LH wing cover, with vents (stock part)
- RH wing cover, solid (stock part)
- Land Rover tape radio AMR2772 (don't have the code but have a VIN from the disco it was removed from).
1 - 4 of 4 Posts
