1 - 5 of 5 Posts
I been battling low oil pressure for a while now. I ordered a new oil pump gear housing, and while it gets here, I was told to check the gap on the main bearings...sometimes you can loose pressure that way? I have the oil pan out. But im not sure which gap im meassuring. Should I remove one of the bearings? Also, I feel a little play on the timing chain. Not much, but I can move back and forth a little. Is this normal? Rover has 145, 000 miles. Head gasket was done. But no work on the bottom half to my knowledge.
Thanks.
-Gabe.
95 D90 NAS
Not sure if the Dro will chime in, but he just sanded the housing. Look at the oil pump gears and check if the housing is marked/scared. I don't think I would worry much about the main bearings this early on.
is the engine making noise? how low is the pressure ?
you can check the rod to journal clearance with Plastigauge - Plastic Precision Clearance Gauges
but if your loosing pressure from excessive bearing clearance most likely your looking at a rebuild
normally you can get away with squaring up the oil pump end plate and a set of gears and stretching the spring
1 - 5 of 5 Posts
