1 - 2 of 2 Posts
1986 LRD RHD 110
1986 Land Rover Defender 110 RHD Bulkhead and Windshield
I have this bulkhead/windshield removed from a 1986 LRD RHD; I am doing a complete restoration/conversion to a PUMA, so you will get everything you see in the pictures.
As it is normal in this type of parts and vehicles ages this Bulkhead have some arear with rust that will need to be repair or replace.
Please take a closer look at the pictures and if you have any question feel free to ask.
I locate in Baltimore, 21211.
Local Pick up only…
Take a closer look at the bulkhead as the following areas.
  • Door post upper right side where the frame for the windshield bolt (rust)
  • Door post upper left side where the frame for the windshield bolt (rust)
  • Windshield frame rubber is worn out, glass is in good condition and heated.
  • Notes:
  • included is what you see in the pictures:
  • Bulkhead
  • Windshield with frame
  • Wiper motor, arms, and mechanics
  • Brake booster and pedal
  • steering shaft
  • steering wheel
  • dashboard wiring harness as seen in the pictures
  • Fuse box and cover as seen in the pictures
  • Center tray or console with cut holders.
  • Blower motor and duct
  • Air filter box
  • Steering column switches
  • Ignition switch and one key
  • Instrument cluster with gauges and odometer
Asking $9
00 OBO
1 - 2 of 2 Posts
