Can I import an LS swapped Defender.
1141 Views 10 Replies 6 Participants Last post by  rdavisinva
Hello ladies and gents,
So happy to join the team here, and I hope all are having a good time.
I have a 110 defender that I restored in Dubai and I want to import it into the United States.
it’s 1994 110 300tdi originally but it was swapped with LS3 and 6 speed auto.
I know that’s not the right thing to do to a defender but the 300tdi will go in my other 110 :)
Questions 1:-
Is it true that can’t import an LS swapped defender because it is not it’s original engine? Please explain.
Question 2:-
If it’s true, does the year has to match the engine spec it had originally? Basically 300tdi for 1994-1997 defenders only and not earlier years?
If there’s a shipping company/ custom brokers, that you know of and might have an answer, please feel free to share their info.
I am seeing so many LS swapped defenders in The Sates and on bringatrailer but I don’t know if they were imporated with their original engines then swapped or wore swapped overseas.
Regards
1 - 11 of 11 Posts
They have to have the original engine or equivalent so no you cannot import a re-engined Defender unfortunately.
This website is very useful.
Reactions: 1
The only way, would possibly be to have the vehicle held in bond while you have a shop approved and registered with the EPA test and certify that the vehicle passes emissions.
This is provided you can somehow pass all the other importation requirements.
If you could be successful, you would likely need an import attorney to process all the requests.
The whole process would cost you a lot of money, probably a lot more than the vehicle is worth.
The easiest way to get it into the US legally, would be to switch it back to a 200TDI (originally typed 300TDI by mistake).
I am as far away as you can get from an LS conversion expert as possible, but it is my understanding that the LS conversion makes a lot of changes that cannot be reversed, at least not easily.
Now that it has an LS, what would it take to convert it back to factory spec is the real question that needs to be answered and is it worth it to switch it back to allow this 110 to enter the country?
Thank you,
when you say equivalent, can it be a 91-92 110 with 300tdi or it must have 200tdi? Which is its original engine in that era.
because I won’t swap my 94 back it’s pain, so I’ll just sell it locally.
and my other 110 is 92 with no engine currently.
The easiest way to get it into the US legally, would be to switch it back to a 300TDI.
Thank you,
no I wouldn’t even bother, I have a seller who’s interested locally.
I’ll keep looking for more info thanks.
Sorry about the typo. I meant 200TDI, but typed 300TDI.
I fixed it with edit.
Reactions: 1
Thank you,
The engine type needs to match the code on the VIN. 300TDIs did not come out until 1994.
Just buy a different truck. Even swapping back, you will set off too many alarms as it will be obvious the frame has been cut for the mounts.
Okay so engine spec matching with vin number.
Great info, much appreciated.
Great info
Questions 1:-
Question 2:-
Regards
My 2 cents..
vehicle no problem, engine might be tough. If the LS3 meets epa regs you might be ok. Dig deeper into the import regulations.
My 2 cents..
The problem is not meeting the specs and regs.
The problem is having the vehicle verified that it actually meets the specs and regs and affording the costs to schedule and then have one of those rare qualified firms that can and will document that the vehicle in question passes the certification.
Big bucks any time you deal with an oligopoly that really doesn't need your one off business.
1 - 11 of 11 Posts
