Anyone have experience with the Britpart disc handbrake conversion? The Terrafirma one seems to be out of stock everywhere and I’ve read some bad reviews of the X-Eng kit.
Just like the older style works perfectly. There is really zero reason to install a disc. People do it because they are too lazy to take an hour of their lives to overhaul the drum style.It's less expensive to buy all new parts for a stock direct-cable actuated drum brake than these aftermarket options. This later style drum brake, when correctly adjusted, works great.
Yes the older style can work well too if the linkage is right. The advantage of the later direct cable style is simplicity in that it has less moving parts.Just like the older style works perfectly. There is really zero reason to install a disc. People do it because they are too lazy to take an hour of their lives to overhaul the drum style.
Terrafirma was allmakes “Offroad accessory “ brand.Anyone have experience with the Britpart disc handbrake conversion? The Terrafirma one seems to be out of stock everywhere and I’ve read some bad reviews of the X-Eng kit.
I had the same thing happen to me. Mine froze up to the point that it was smoking out in the middle of the Ocala National Forest in Florida. I had to take it apart to free it up and it took a couple hours to cool down. I have since installed the X-brake and its a lot easier for me to understand and work on.I put in the X not because the original did not function well, but because it froze on me out on a trip. I was lucky to have a torch handy but did not enjoy warming it up in 8 degree weather (yes, on me that I used it in cold, but I want to be able to use the brake while I’m sleeping in a RTT)
