1 - 11 of 11 Posts
Read Only
My blown up motor from a few years back.
Comes with:
  • block
  • head in great shape
  • injecotr tips (uninstalled)
  • oil pan
  • oil pump
Bottom end is pretty well fucked, probably needs a crank. I can pallet or put onto a rolling dolly. You pay shipping.
$700
Does not come with: injection pump , timing case or clutch housing, manifolds
Read Only
Do you know how many miles were on it before it blew?
unsure, blew due to low oil pressure after a catastrophic oil leak at highway speed. oil pressure light flickered for about 5 seconds then solid red as i was slowing down, then nuke.
The cyl walls still have cross hatching and there is no "lip" or ridge at the tops of the bores, so im assuming less than 200k.
I can take pics for an interested party.
Thuis engine shoudl be treated as the base for a build, expect o either grind the crank or get a replacement. They go about about £45 used on ebay.co.uk or about $300 new.
Cam looks good from the access ports, head looks fine. Willing to cut a deal with the other parts listed
If the head is good and the right price I'll take it.
1 - 11 of 11 Posts
