Hello,
I need to replace my battery for Battery requirement for 1988 D-110, Petrol, LHD, ROW, 2.5 L.
Any idea on what I should buy? I was thinking Autozone or some local shop. Any help is greatly appreciated.
Thank you,
Binesh
I use group 34 batteries in my defender, and I want no less than 700Cold Cranking Amps for my starting battery(I use an optima red top for my starting battery), my house battery is a Group 35 Yellow top with 620CCA, usually if you are dual battery you want both batteries to be the same, but im using a 20A DC-DC charge controller to keep the house battery topped up, so its less of a concern. Costco or Autozone should be able to get you a battery for your needs, check the one you have in there, sometimes they are Negative Left, and Sometimes they are Positive Left
Thank you Seekerbeta!
Thanks everyone. Got an Autozone battery. Car starts fine now, and runs fine. Thank you again.
