1 - 13 of 13 Posts
A friend drives a DiscoI with 300tdi engine, R380 and about a 2" lift.
This was fine untill he swapped a ZF auto gearbox.
Since then he has bad vibrations when driving more than 90m/h.
Torque inventer and flex plate had been changed: same vibrations
He had changed several types of transmission boxes: same vibrations
Took the front shaft out while driving in diff-lock mode: a little bit smoother vibrations
He's thinking about the gap inside the main shaft inside the auto gearbox. It's about 0,8mm.
Expereances are needed.
Quickly if possible. :grin
And a tipp about how to measure the gap the easy way!
Thanks.
Kurt
The problem is he switched from a manual to an automatic. Put the R380 back in and it will be fine.
Is he using the same drive shafts?
He wanted an automatic like me.
Drive shafts: good question. I guess he replaced them by wide angle or double joint types.
But it doesn't matter, both sytems failed: because bad vibrations
We had a similar question a few days ago.
1: check UJ for play and regrease
2: check props hafts at both ends to make sure the nuts securing then are tight
3: one extra one: ditch the guibo/rubber donut for real props haft
Discussion Starter #8
I'm sure he checked it all over the place several times!
No ideas about vibrations inside the automatic transmission? :popcorn:
A binding u-joint will cause a vibration before there's any play in it. And it can only be checked by removing the propshaft.
Discussion Starter #11
People can actually do 90 miles per hour in a Rover? Seriously?
I'm sorry for this mistake. A small "k" is missing. :hide:
The vibrations start at 55 m/h.
Had a problem with vibration. Checked many many things. eventually found the big nut on the pinion gear on the front of the rear diff was 'loose'. the shaft could be pushed and play felt. tightened the nut to 90nm and vibration was gone,
Had a similar issue and it turned out the bolts securing the driveshaft to the back of the transmission were slightly loose causing the break drum set screws to work loose and then the parking brake drum to rotate and wear the holes oval where it fits onto the rear flange.
It was pretty ease to diagnose.
1 - 13 of 13 Posts
