41 - 49 of 49 Posts
· Registered
I have had mine installed for 8 months now.
support is excellent, Wiring it up was a challenge.
we are driving 30 year old trucks not designed to be comfy. MOD hvac is a great improvement, but it’s
not modern day cold and heat.
I agree with Ozzie’s post.
· Premium Member
Go Mundo Maya!
Discussion Starter · #42 ·
What was the wiring challenge?
· Registered
I'm getting ready to install my system and was wondering, from those who have done it, if you have any tips and/or recommendations for the install - now that the product has been on the market for some time?
I also need to source an AC compressor, condenser and fan set-up. Does anyone have any recommendations (4.0L Rover V8, stock viscous fan, stock radiator).
Thanks in advance.
· Premium Member
1995 300tdi ROW
pretty much how I wrote it up in an earlier post. I do wish I opened up the hole into the cabin to see if air flow would be improved or not..
oh, and I used oem compressor so id imagine you can pick up whatever components you need(oem/aftermarket)
· Registered
When I installed mine I mounted the HVAC unit under the hood on the firewall in the correct position, then I marked the hole into the cabin to match the outlet of the MOD unit. Then simply removed the unit and cut the hole to match. It was very simple!
41 - 49 of 49 Posts
