So the tape deck has been working sometimes, and not others, and my wife got me a replacement head unit from Crutchfield for Christmas. It came with the "70-1758" wiring adapter (Audi VW, Saab, Merc and 02-03 Freelander)..
I spent an hour or two carefully joining the radio harness to the adapter, pulled the Factory Radio from the truck, and found that the two connectors in the tuck do not plug into the adapter harness. The one will connect to one side of the adapter harness Molex, but the speaker connections plug is both too long, and has the locking clip offset..
I called Crutchfield tech support and discussed with two different techs, who both assured me I had the correct adapter harness. One suggested cutting end out of the Molex block to accept the speaker connector (it has positions for 10 connections, but only uses 8, so in theory could work), except the locking clip is offset on the factory connector, and centered on the Molex adapter, so still won't physically connect. I could theoretically cut the top end of the adapter out so it would plug in and use a zip tie to assure it doesn't come apart I guess..
I searched and found three threads with lots of good info, one of which describes pretty much the same issue back in 2007 with the Crutchfield supplied adapter (way to go updating your documentation Crutchfield). And multiple posts saying just search for a Rover adapter online, but I've done that and come up with nothing.
Was wondering if anyone had come across an adapter that works, I'm NOT cutting the factory harness..
Earlier Threads I located and mentioned above:
www.defendersource.com
There is also an issue with the 1995 that the factory amp needs a turn on lead (no amp in '94, not sure how '97 crosses over). It is covered well in the threads linked above, but worth noting for anyone else that may come across this looking for answers. But this will have to be addressed outside of the adapter I assume?
Ultimately would love to find an adapter harness or pair of harnesses that are exact fits, hoping someone has come across it and I just can't find it with my search skills..
Attached are the further details supplied by Crutchfield tech..
SOLUTION FOR THOSE WHO DON'T WANT TO READ THE WHOLE THREAD - The Metra 70-9400 is the key to installing aftermarket HUs in the 1995 truck with the factory amp.
Radio Upgrade
I searched first and found many things but most are inconclusive. I just received a Pioneer head unit to replace my ailing stock one. I ordered from crutchfield. The wiring harness that they supply is for a VW/Audi. It looks like it fits but it doesn't. The factory grey plug will fit into...
radio/speaker connection.. not in archives. help!
Hi all., I am currently installing a new kenwood stero in my 95 90. I have wired it all according to the archive info (wire color connections, etc) here is my problem no sound is coming out of any speakers. the radio and all it's functions work fine hooked into the rover. i...
'97 NAS D90 Radio
Hopefully none of this is new to somebody and a quick assist is available. The LR stereo system in my D90 quit, so the kids bought a new one to install. Installation went fine and the radio appears to be working, all the right visual cues, but there is no sound. I pulled the wiring info for...
