201 - 220 of 321 Posts
Discussion Starter #202
Great!
Let me know if they install ok. Someone made the great suggestion of adding washers to the kit which is not a bad idea. The nuts are small and the holes in the body panel may be bigger. Take a look before you install.
Agreed , Bill pkg looked good! Carl they were a snug fit over the plastic, but nice and tight. so tight barel need the screws. but have a lot of work to do because the PO hacksawed off the rivinuts!
DAMN....that's some fine bit of kit! Makes me wish I still had square tail lamps. Might be time to break open the piggy bank.
Discussion Starter #211
As long as you're happy with the fit and quality, Mark, then I'm happy as well. Here's an update to whats currently available. The stock is limited because I don't know if and when I'll be making more. Once the final order of rear guard ships out I'll be putting these projects on hold for a little while to shift my focus elsewhere.
The orders for the aluminum surrounds have completely stalled so I'm debating if I should refund you guys and have you re-order when I'm able to re-launch them via a crowdfunding campaign. I don't like the idea of sitting on your cash without a target date in mind. For those of you who have pre-ordered, can you let me know your preference? I really want a pair of the surrounds for my own truck but I realistically probably won't get to making another attempt until this fall due to so many other things going on. Let me know.
Quantities still available:
Small Guard set: $240/set* - 12 sets left - Final Quantity.
Headlight Surround set: $340/set* - 20 sets left.
OEM Grill: $440/each* - 9 units left - Final Quantity.
*after the 20% D-Source Discount has been applied.
How many of us were there? I'd transition to a grill (obviously with cash on top.) I need the surrounds more though, and hope that you achieve mos one day! Just let me know as I'd still be in for a set when they go to press! All the best - Dave
Discussion Starter #213
They will happen one way or another. The tooling is the expensive hold up. We're 28% there. 5 orders placed. Need 14 more orders... unfortunately, in order to cover tooling. We can also make them without tools (CNC) but they will be $1K/set ;)
Discussion Starter #214
The files for the final order of rear guards have finally been submitted for laser cutting. I apologize for the delay, guys.
So what are we going to do with regards to the surrounds? I can transition to a grill and just keep my name on the list for the surrounds as a guaranteed buyer. I was going to get the grill this month anyways so you know I'm good for the surrounds when they finally do happen. Just let me know. All the best – Dave
Discussion Starter #217
Hi Ed.
I have been promised a pick up from the laser cutter this Wednesday. Another couple of days to get bent and welded and another week on top of that to get anodized.
------ Follow up post added May 25th, 2015 11:44 AM ------
David.
I'll most likely just end up refunding everyone until I am able to take another stab at it. Most likely I won't be able to touch it until fall and I don't feel comfortable hanging on to everyones cash for that long. I don't care if these go into production, I just want a set for myself so I end up having to CNC a set at an obscene cost so be it. It was never about the money or the "opportunity". Crowdfunding may be the way to go but I will be neck deep in the Field Knives this summer which is why I'll have to postpone this project.
Discussion Starter #218
I have issued a refund to those of you who placed an order for the headlight surrounds. It's not game over yet. I will make another attempt via a crowdfunding campaign later this fall. Please check that you have received the refund. I received an inquiry about someone wanted a set for their Twisted Defender. Perhaps I should give Twisted call to see if they are interested in expediting the product development.
The laser cutter used my old files to cut the mounts for the rear guards so they had to re-cut them and I am picking them up today to get them sent over for fabrication. I will post up when I hear more on when that is done.
Ok. Bummer. Let me know when funding starts again. I really want these! ;-) I'll have a look see on the refund, but I'm sure it's fine. What's the discount code on the grille? Still the same?
Discussion Starter #220
I know, its a bummer but its not over yet. We'll get some made one way or another. I sent a note to Twisted. :)
Yep, the code for the grill is the same.
