1 - 8 of 8 Posts
I installed LED lights today including the correct flash relay...all four flashed regardless of the stalk position....I removed the dash indicator and it corrected the issue as it's allowing a small amount of current to pass through the bulb to the other side...how does one correct this so I can still have a dash indicator?
I searched and found the bulb removal but no one said how to rectify the issue...
Even with the new relay...did the indicator on the dash work correctly too?
I initially installed rears only and changed out the flasher - all was good (dash bulb flashed as well).
When I installed the fronts is when all four blinkers flashed.
Seems not everybody has the same problem - mine's a 97 NAS. At the core of the issue I believe is the LED's don't draw enough current compared to incandescent - it may be compounded as well by the single bulb indicator in the dash.
Discussion Starter · #8 ·
Yes the side repeaters need a swap out but since I am going to LRD I will still need the fix...that post is perfect Oscar! Thanks.....I wish the search function was a tad better...always have to search through google!
1 - 8 of 8 Posts
