Don't remember if the 95 did, but if you still have the round glass fuses test each side with a rest light and fix the connections if they are not providing continuity.
Thank - as far as I know there are two fuse boxes the one in the cab that has almost all of the fuses and the one in the engine compartment that has the 3 larger 55/60amp fuses…
So I double checked all the fuses and nothing seems to help… According the the label on the inside of my diesel cover fuse #5 should be the tac, however it’s also supposed to be the turn signal and that IS working.
I think 5 is your gas gauge—looks that way from wiring diagram. Don’t think tach is fused, at least not on diagram. Check white/Black wire coming off coil. That I believe is tach signal. At least on NAS ‘94. Don’t think it’s related to air con. I’ll dig a little in the wiring diagram
All of the gauges have a ground that go into a connector. Check there. Some of the grounds go into the firewall and are connected to a ring terminal in the center top of the bulkhead inside of the engine compartment. I inserted new Ground wires to a better ground and ground at the body in a better fashion to the chassis and the battery. The grounding on these things is terrible. Check all of that, there is a link in the last few posts of new posts about PDF manuals. Look in there for the electrical diagram
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
