1 - 10 of 10 Posts
Pulled from our stock what I believe to be a LHD TDI accelerator cable for a 90/110/130.
The cable measures 61.5" end to end.
Since the inner cable has swaged ends, the measurement is end to end based on the inner cable, NOT the length of the cable housing.
The 61.5" is just about 4" short for the application which is a 4JB1-T into a RHD 110.
The concern is that there may not be a cable supplied by Land Rover that is long enough for this conversion.
Does anyone have an assortment of Land Rover accelerator cables who can measure the longest one to see it it is 64" or longer?
Want to check for a Genuine cable before making up a custom one.
Already called RN and they are out of stock until their next order comes in.
Called Eric at AB and they only stock cables for US spec vehicles which are about 35" max.
i just bought a 200tdi RHD cable that is super long for some reason not what i expected i will measure it up when i get home tonight.
The one i had on my truck was about 32" this one was almost twice as long and on the package it said 200tdi rhd.
I got one that's 64 inch dead on.
Not sure of the part#, was to long for RHD 200tdi
64"is the length of the other cable
Do you have the part number?
Confirming it''s RHD 200TDI or another application???
Want to sell it?
RHD 200tdi cable is 45 inch
So what you have is a LHD 200TDI Disco and the inner cable measures 64 inches... correct?
Right-hand drive 200 TDI no difference between the defender and discovery Cable length is 64 inches
I expect it really is for left-hand drive but the packaging says right and drive and so does the part number
Discussion Starter · #9 ·
LHD 200TDI Disco is NTC 7227 and LHD Disco Defender is NTC4945.
The Disco version is about 60% more than the Defender, so I would think this means the Disco cable is longer, but with Land Rover you can never be sure until you are in the process of measuring or fitting... all part of the fun we endure with these Solihull Treasures.
I make the RHD disco 200 Tdi ANR 2359 Disco's have a different bulkhead fitment to the 90/110&Defender
200 Tdi RHD 90/110 Def ANR 1860 (was NTC 4944)
300 Tdi RHD 90/110 Def NTC 9360
200 Tdi LHD 90/110 Def NTC 4945
300 Tdi LHD 90/110 Def NTC 9359
and 200/300 Tdi RHD ANR 3606 RRC&Disco
I am sure there are others, I just know the "short" 45 inch cable fits the LR90 200Tdi as I have one fitted.
1 - 10 of 10 Posts
