1 - 20 of 41 Posts
Here is the scenarios: Hot day in the 30s (Celsius) going slow low gear up hill following other trucks through a trail in the bush.... Over a period of 15 min the needle slowly rises and finally verges on the red before I stop and let it cool.... Rad fluid comes out of the overflow (I.e. There is enough there) Engine fan turning. Small fan on front of rad not coming on that I can see... Is this stock? NO problems at all going highway speeds up long hills at high rpm. Any suggestions?
Possibly a side issue.... Air con pooped out after several stops to cool.
It seems to maintain temp when idling or even cool off slightly when in a near overheat situation. Does that still sound like the water pump? And what about that auxiliary electric fan? Is that stock on 97s?
Lets see what others say on the running hot, I still think it is the water pump. As for the little fan, that fan only turns on when your radiator/engine are about to reach critical mass (melt down) on a 97.
off road= little to no airflow, possibility of obstruction, thermostat. I would look into cleaning/radiator recore. most common failure of our 20 yr old machines and most overlooked component until it fails.
I had this issue with my 97SW. Replacing my water pump solved my problem. My aux fan crapped out years ago and I decide to just remove it. I don't have problems cooling with the AC running. Temp gauge pegs at TDC and never moves. I also changed my vFan, hoses and tstat all at the same time. All these components had 110k so I felt it was worth the splurge given what over heating these engines does.
It "was" a Buick engine for only a few years in the sixties. There are many, many more Rover versions of the engine than there ever were made by Buick.
Discussion Starter · #18 ·
I hear Ya. Rock Auto I believe has cross referenced parts for the D. I'd probably support the indie Rover guy unless the price point is way out in left field somewhere.
I would love to unless I can get it locally...
Doesn't make sense to pay two sets of import duties...
<-- Canadian
Is there anything else I should do preventative/upgrade at the same time?
I disagree with the advice diagnosis above. if it cools fine @ highway speed then the water pump is circulating the coolant and air is being forced through the radiator and it cools. If its getting hot on a trail i would suspect the fan clutch not the water pump.
1 - 20 of 41 Posts
