Hopefully none of this is new to somebody and a quick assist is available. The LR stereo system in my D90 quit, so the kids bought a new one to install. Installation went fine and the radio appears to be working, all the right visual cues, but there is no sound.
I pulled the wiring info for the D90 from the forum, though the only info available was relative to 1994 Defender 90 Radio Wiring (http://www.defendersource.com/forum/attachment.php?attachmentid=28494&d=1276289063).
D90 Harness to Radio Harness
Purple = Battery positive (always hot) to Yellow
Orange w/White Stripe = Ignition Switched positive to Red
Solid Black = Ground Black
Red w/Black Stripe = Light Switched positive to Orange w/White Stripe
Yellow w/Purple Stripe = :confused
First question: What is the Yellow w/Purple Stripe wire in the D90 radio harness?
D90 Speaker Connects
Left Rear positive = Black w/Green Stripe
Left Rear negative = Black w/Blue Stripe
Right Rear positive = Black w/White Stripe
Right Rear negative = Black w/Brown Stripe
Left Front positive = Black w/Yellow Stripe
Left Front negative = Black w/ Orange Stripe
Right Front positive = Black w/Pink Stripe
Right Front negative = Black w/Red Stripe
Next questions: Can you see something obvious that I have done incorrectly? If not, are there suggestions for either testing or fixing?
The new radio is apparently working, indicating receiving a strong signal, identifying the radio station, connecting to the blue tooth phone, etc.
Thanks,
Mike
Thanks,
Mike
