1 - 12 of 12 Posts
Been told dog lights, cruise control wont stay on due to weak fuse box. Eh....?
Willing to try I guess if can find
Rangerovers.net
Not sure what dog lights are?
Cruise control maybe split vacuum hose?
As for the lights, are they wired as fog or driving? You can change the switch for either. As fog only come on with dip beam, driving when high bean on. Can't see how both (cc&lights) are connected. Has this just started or is this a new to you rangie?
Always been that way and I've had to different shops diagnose, both came back w a weak fuse box by footwell.
Discussion Starter #10
That looks correct as far as I can tell..
Messege me w what your needing for it and it will need to go to 82520 area.
Thanks
That will be alot of work changing that out. It will never be right? Have you tried jumping the power leads to see the issue?
The fog/driving lights can be workable with a off the shelf relay harness, cc if you really need it.
Good luck in your quest.
1 - 12 of 12 Posts
